rooler
Oct 23, 2015Aspirant
Netgear AirCard 785S USB tethering does not work with El Capitan
Hi, After upgrade to El Capitan, I've noticed that my USB tethering stopped working with the Netgear AirCard 785S on my MacBook Pro. When I plug in the AirCard 785S through USB, and open the Syst...
DarrenM
Oct 26, 2015Sr. NETGEAR Moderator
Hello Rooler
Have you tried to reinstall the Aircard? try to remove the connecting and re tether it to the Mac.
DarrenM
- roolerOct 31, 2015Aspirant
I did try to remove and insert again, nothing happens. What do you mean by "reisnstall" though" Are there any drivers to install?
- DarrenMNov 19, 2015Sr. NETGEAR Moderator
Hello Everyone
I got a update on this issue this should be fixed during the next apple update of OSX 10.11.2 release but we do not have a ETA on when apple is planning to do this.
DarrenM
