djnmv
Jun 26, 2018Aspirant
Netgear Aircard 790S & Smart Cradle Docking Issue
Hi,
I have a Netgear Aircard AC790S which is working fine and I can connect to the wireless SSID being transmitted from this device successfully and browse the internet on my devices OK.
jamesreynolds
Mar 04, 2019Aspirant
I'm having this exact issue. The cradle says there is internet but it won't work via cable or wifi, but if i connect to the hotspot directly then it works. Any suggestions? I'll be down at that office later this week so I'll explore additional info and report back (if I remember)
- jamesreynoldsMar 10, 2019Aspirant
turned out to be a an IP conflict, so just network config error. Nothing wrong with the cradle in the end.
- GimmieJul 16, 2019AspirantI have the same exact problem and it’s not clear to me how to solve it. If it’s because of IP conflict! How can I overcome this issue? Please support.
- jamesreynoldsJul 21, 2019Aspirant
If it is an IP conflict then you'll have another device in the network which is supplying IP addressess too (acting as a DHCP server). For me, we had a network switch acting as DHCP which was not something I had encountered before. Just try unplugging all the network devices from the back of the cradle (ethernet cables) then connect directly by wifi to see if it works again. You may want to consider doing other suggestions here too (factory reset on it / check firmware) if you keep having difficulties. If you only have a PC (no wifi) then only connect the PC directly to the cradle (nothing in between) to test if it works that way, hope this helps
