djnmv
Jun 26, 2018Aspirant
Netgear Aircard 790S & Smart Cradle Docking Issue
Hi,
I have a Netgear Aircard AC790S which is working fine and I can connect to the wireless SSID being transmitted from this device successfully and browse the internet on my devices OK.
jamesreynolds
Mar 10, 2019Aspirant
turned out to be a an IP conflict, so just network config error. Nothing wrong with the cradle in the end.
Gimmie
Jul 16, 2019Aspirant
I have the same exact problem and it’s not clear to me how to solve it. If it’s because of IP conflict! How can I overcome this issue? Please support.
- jamesreynoldsJul 21, 2019Aspirant
If it is an IP conflict then you'll have another device in the network which is supplying IP addressess too (acting as a DHCP server). For me, we had a network switch acting as DHCP which was not something I had encountered before. Just try unplugging all the network devices from the back of the cradle (ethernet cables) then connect directly by wifi to see if it works again. You may want to consider doing other suggestions here too (factory reset on it / check firmware) if you keep having difficulties. If you only have a PC (no wifi) then only connect the PC directly to the cradle (nothing in between) to test if it works that way, hope this helps
- GimmieAug 12, 2019Aspirant
Thank you for your response, and sorry for delay!
actually there is no connected devices to the smart cradle, and what is really weird to me when i try to dock my Aircard 790s to the cradle it only charge my Aircard 790s!, BUT when i connect it using the usb port it works with no issues woth passing the internet through it.
now i am losing a usb port which i may use for external storage as media center.
if the Aircard 790s working fine with usb and pass the internet on IP 192.168.1.4 which is the default, is it a problem of the port itself i need to configure on the cradle or what?!!!
- jamesreynoldsAug 12, 2019Aspirant
The cradle shouldn't need any setup, I just factory reset it and it works straight away. It does take a while to start up though.
Does the internet symbol light up when you plug the aircard into the cradle? (3rd in from right) Do the wifi symbols light up? (on the far right)
Don't forget that you need to connect to a different wifi when it's in the cradle - see the bottom of the cradle to get the info.
