djbeast
Nov 26, 2017Aspirant
Netgear Aircard 790S problem connecting to Nintendo Switch
Hello. Im new here and I need you help please. Im having problem connecting my Nintendo Switch to my Netgear Aircard 790S to play online games. Im getting and error on Switch that says : Unable to co...
DarrenM
Nov 29, 2017Sr. NETGEAR Moderator
You may need to do some port forwarding for the nintendo switch.
DarrenM
- djbeastNov 30, 2017AspirantHow do I do that?
Can you please help me?- DarrenMNov 30, 2017Sr. NETGEAR Moderator
Here is how to enable port forwarding
https://kb.netgear.com/23675/Enabling-Port-Forwarding-Filtering-on-an-AirCard-Mobile-Hotspot
Here is the ports you will need to open.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/651/~/how-to-set-up-port-forwarding
DarrenM
- djbeastDec 01, 2017AspirantThank you for your reply!
Nope , even if I use port forwarding , it doesnt working. They told me that the problem is with NAT. When Im using as a hotspot the netgear , then Im getting on switch NAT type C. When Im using as a hotspot my smartphone , Im getting on switch NAT type B , and only then I can play online. Is there a solution about that?
