Recliner22
Oct 04, 2015Aspirant
NETGEAR AirCard Signal Boosting Cradle with Ethernet - DC113A
I would like to purchase a NETGEAR AirCard Signal Boosting Cradle with Ethernet - DC113A but I can't find a source. Amazon says they are unavailable and doesn't know when or if they will get them.
Does anyone know if this cradle will be available, when, where and how much?
Thanks
Hello Recliner22
Sorry to say but this product is end of life and isn't going to be restocked but i did find that the UK amazon still has some in stock.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello Recliner22
DarrenM
- Recliner22Aspirant
DarrenM,
Since the cradle you mentioned is being sold in the UK, does that mean that it will only work on 220VAC or can I get a 110VAC power supply from Netgear?
Thanks,
Preston
PS: Will this cradle work OK in the US? - Recliner22Aspirant
DarrenM, Thanks for the reply and the info. Do you know if Netgear is going to come out with a new cradle for the AC791L Hotspot, or are they disconiuing it also?
Thanks,
Preston
Recliner22
yes this should work in the US just fine and I dont have any information about a new cradle for aircards.
DarrenM
