e3radi's avatar
e3radi
NETGEAR AirCard Smart Cradle (DC112A) asking for password
hi
My NETGEAR AirCard Smart Cradle (DC112A) asking for password when I try to connect with it and its not allow to connect, And I must switch the router off and switch it on again to connect without askin the password!!
I try to rest the router but the problem still there .
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello e3radi
    By default the router password should be password and have you tried to do a factory reset by holding in the reset button on the back for 10 seconds.
    DarrenM
    • e3radi's avatar
      e3radi
      Yes I try that but still after that the problem return again
