alitech
Jan 10, 2019Guide
Netgear lb2120 wireline unavailable
Hi guys
Just purchased this to get some failover action for my broadband. I have been able to get it to work with 4G and its what I am using right now. I have configured it to bridge mode and als...
alitech
Jan 14, 2019Guide
Has anyone got any suggestions on this? I purchased this through amazon and I just received a replacement because of this issue. Same problem with the new one that was just delivered today.
- dc5ddJan 18, 2019TutorThe LB2120 is limited in what it can do that being said it does what it is meant to do with some simple settings and option. I believe the merging of cellular and broadband protocols might cause some problems.
Anyway netgear products seems to work with each other better especially the newer products. I had a linksys e3000 and that never worked with the lb2120. Now I use R7300 and that works with the lb2120 in router mode.
