alitech
Jan 10, 2019Guide
Netgear lb2120 wireline unavailable
Hi guys
Just purchased this to get some failover action for my broadband. I have been able to get it to work with 4G and its what I am using right now. I have configured it to bridge mode and als...
alitech
Jan 14, 2019Guide
Has anyone got any suggestions on this? I purchased this through amazon and I just received a replacement because of this issue. Same problem with the new one that was just delivered today.
dc5dd
Jan 18, 2019Tutor
The LB2120 is limited in what it can do that being said it does what it is meant to do with some simple settings and option. I believe the merging of cellular and broadband protocols might cause some problems.
Anyway netgear products seems to work with each other better especially the newer products. I had a linksys e3000 and that never worked with the lb2120. Now I use R7300 and that works with the lb2120 in router mode.
