alitech
Jan 10, 2019Guide
Netgear lb2120 wireline unavailable
Hi guys
Just purchased this to get some failover action for my broadband. I have been able to get it to work with 4G and its what I am using right now. I have configured it to bridge mode and als...
Audrey76
Mar 15, 2019Aspirant
Techsticles wrote:
By default the LB2120 pings 8.8.8.8 by default. If it can reach it on the WAN port, it knows the connection is live. psiphon If not, it fails over to LTE.
You can add other IP addresses and websites to ping before failing over in settings.
Facing the same problem, please help me.
Blanca_O
Mar 21, 2019NETGEAR Employee Retired
Hi Audrey76
I would like to know if you enabled the LTE modem's failover feature? If not, please disable it and apply the settings. Once done, please restart your modem and check if the wireline is still unavailable. To do this, please check this link: http://www.downloads.netgear.com/files/GDC/LB2120/LB2120_UM_EN.pdf [page 21]
Blanca
Community Team
