49studebaker
Aug 02, 2016Tutor
Netgear LG6100 USB file sharing
The Netgear LG6100 USB file sharing works fine with Windows 7. I can not access the LG6100 USB drive file share from a Windows 10 pc. Is there a bug in the USB Control Center Software or is there a b...
49studebaker
Aug 15, 2016Tutor
It's an LG6100.
DarrenM
Aug 22, 2016Sr. NETGEAR Moderator
Hello 49studebaker
What is the message that it gives you when trying to access the shared drive?
DarrenM
- 49studebakerAug 29, 2016Tutor
I do not get any messages. On my Windows 7 laptop, if I click on "Mass Storage" that appears in Netgear USB Control Center, then a window appears that displays the contents of my USB drive. My USB drive also appears under "Network" in "My Computer".
I do not get any messages. On my Windows 10 laptop, if I click on "Mass Storage" that appears in Netgear USB Control Center, then a "My Computer" window appears, but my USB drive's contents are NOT shown. My USB drive does NOT appears under "Network" in "My Computer".
