49studebaker
Aug 02, 2016Tutor
Netgear LG6100 USB file sharing
The Netgear LG6100 USB file sharing works fine with Windows 7. I can not access the LG6100 USB drive file share from a Windows 10 pc. Is there a bug in the USB Control Center Software or is there a b...
DarrenM
Aug 22, 2016Sr. NETGEAR Moderator
Hello 49studebaker
What is the message that it gives you when trying to access the shared drive?
DarrenM
49studebaker
Aug 29, 2016Tutor
I do not get any messages. On my Windows 7 laptop, if I click on "Mass Storage" that appears in Netgear USB Control Center, then a window appears that displays the contents of my USB drive. My USB drive also appears under "Network" in "My Computer".
I do not get any messages. On my Windows 10 laptop, if I click on "Mass Storage" that appears in Netgear USB Control Center, then a "My Computer" window appears, but my USB drive's contents are NOT shown. My USB drive does NOT appears under "Network" in "My Computer".
