49studebaker
Aug 02, 2016Tutor
Netgear LG6100 USB file sharing
The Netgear LG6100 USB file sharing works fine with Windows 7. I can not access the LG6100 USB drive file share from a Windows 10 pc. Is there a bug in the USB Control Center Software or is there a b...
49studebaker
Apr 14, 2017Tutor
Is there a bug in the Netgear software, or is there a bug in windows 10?
schumaku
Apr 14, 2017Guru - Experienced User
Most likely neither.
Open Windows Explorer, (assuming you have not reconfigured the router form it's default IP address) type \\192.168.0.1\ and press the <Enter> or <Return> key and see ... Unless it's a locked-down system, unless there is some incompatible Internet "security" garbage software in place, or the SMB/CIFS 1.0 protocol support was intentionally removed from the Windows features, Windows 10 will assist you typically to change the network location. The common default for a "public network" will block the storage service announcement as well as mounting a shared folder from the cmd line.
Note: The USB Control Cenrer software is not required to access the USB plugged stroage over the (W)LAN.
-Kurt
