786Puru
Sep 26, 2022Follower
Netgear M1 not connected to the router.
Hi Folks!
I hope everyone is doing well. The reason for writing is I was trying to setup my visible sim to netgear M1 router. But, It’s saying no devices found or insert sim card . Even though the sim is inside.
However, I read all the threads relating to setup router with new visible sim. Even after applying APN instructions from you folks. It’s still saying not connected. So, what would you folks have suggestions for me to setup the M1 router with Visible sim. Please guide me in this. Hope to hear positive response from you folks. Thank you
SKU: 6420B
MAC: 100C6B7CDD97
Model: MR1100
SKU: 6420B
MAC: 100C6B7CDD97
Model: MR1100
1 Reply
- W1lliamVirtuoso
6420B basically is a locked model, you would need to check whether or not this device is unlocked or you are using a SIM card that is allowed to have hotspot installed. APN needs to be set for that particular SIM card, different from one carrier to another if your device is unlocked.
