Bigmuzzy's avatar
Bigmuzzy
Follower
Oct 30, 2017
Netgear M1 reboot when plugin tf card or usb drive.
Hi there, I have a Netgear M1 (telstra version) and update to newest firmware 10.16.04.04
And I found when I plug in a tf card or a usb drive, the router will be automatic reboot every few seconds.
the usb drive and the tf card is format as NTFS, and only some mp3 files in it.
without the storage, it looks works well (at least no reboot in couple of hours)
any suggestion or solutions?
Thanks!
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Bigmuzzy,
    You can try the suggestion of Wstyle1 to reset the router and check if the same problem.
    • JamesGL's avatar
      JamesGL
      Hi Bigmuzzy,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      • ArodiD's avatar
        ArodiD
        NETGEAR Expert
        Hi  Bigmuzzy,
        Can you please advise how the M1 is powered up?  Is it using the supplied PA and cable?  Do you also have a battery plugged into your device which has sufficient charge?
        Kind Regards,
        ArodiD
