MichaelDam's avatar
MichaelDam
Follower
May 19, 2022
Netgear M2 Router
Hello
I bought a new M2 NightHawk router.
After an update my router is showing a weard icon.
If I enable tethering over USB and disable the wireless network, my router show the following: A grey dot on the left wireless symbol.
It looks a bit weird...
FirmwareVersion: NTGX24_10.17.08.00
PRI Version 05.04
Web App Version MR2100-100EUS_04.02.171.00
Modem Version SDX24_10.25.00.06
Kind regards
Michael Damaschke
1 Reply
  • plemans's avatar
    have you logged into the app to check it? I don't have one to compare but it could just be a notice that you're using tethering.
