bary35
May 16, 2023Follower
Netgear M5/M6 cooling stand?
Hi, I have an MR6150 inbound. I will be using this outdoor, and it may be subjected summer temps (Midwest US) and direct sunlight. It looks like the M5 and M6 are basically the same size? Does anyone have a cooling solution they would share? I have looked on Thingiverse and found some things for the M1 (different case), but nothing for the newer hotspots. TIA!
I could do your best to keep it out of direct sunlight. Certain plastics break down/weaken under UV light from the sun. Plus shade will help it from getting to hot.
