I_Must_Know's avatar
Aug 28, 2026
Netgear Mobile App blocked notifications
Hello everyone.   I've been unable to find a solution to this issue.   It's weird enough that Android has this app under System apps. But the OS will not allow notifications from the Mobile App ...
  • HappyCat's avatar
    Sep 01, 2026
    How is this MR6150 deployed?  Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
    And, if it is mobile, I would think it should be within reach.
