I_Must_Know
Aug 28, 2026Tutor
Netgear Mobile App blocked notifications
Hello everyone. I've been unable to find a solution to this issue. It's weird enough that Android has this app under System apps. But the OS will not allow notifications from the Mobile App ...
- Sep 01, 2026
How is this MR6150 deployed? Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
And, if it is mobile, I would think it should be within reach.
sulaxna068debi
Aug 30, 2026Aspirant
Hello,
I had a similar issue before. Since it’s listed as a system app and Android keeps switching notifications back off, it may be a system-level restriction rather than a normal app setting. I’d check battery optimization, notification permissions, and whether the app is restricted by the device’s system settings.
I_Must_Know
Aug 31, 2026Tutor
Thank you, sulaxna068debi, for the suggestions.
What's driving me crazy is the 3 dots are not there in app info.
I believe those missing dots is what I need to fix this.
How do I get the 3 dots to appear?
I have a Tab S9 running Android 16 and I'm having the same problem.
