I_Must_Know
Aug 28, 2026Tutor
Netgear Mobile App blocked notifications
Hello everyone. I've been unable to find a solution to this issue. It's weird enough that Android has this app under System apps. But the OS will not allow notifications from the Mobile App ...
- Sep 01, 2026
How is this MR6150 deployed? Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
And, if it is mobile, I would think it should be within reach.
HappyCat
Aug 31, 2026Virtuoso
Page 18 of the User Manual for M6 mobile routers appears to say that the Insight app is used on them as well.
Which specific mobile router uses the Netgear Mobile app rather than Insight?
