I_Must_Know
Aug 28, 2026Tutor
Netgear Mobile App blocked notifications
Hello everyone. I've been unable to find a solution to this issue. It's weird enough that Android has this app under System apps. But the OS will not allow notifications from the Mobile App ...
- Sep 01, 2026
How is this MR6150 deployed? Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
And, if it is mobile, I would think it should be within reach.
I_Must_Know
Aug 31, 2026Tutor
I just installed the Insight app and its nothing like the Mobile app. The Insight app just manages your Netgear account but it doesnt handle the settings within the M6 hotspot like the Mobile App does....or use to.
The only 2 options I have is to install Mobile App and forget about notifications.....or use the weblink.
