I_Must_Know
Aug 28, 2026Tutor
Netgear Mobile App blocked notifications
Hello everyone. I've been unable to find a solution to this issue. It's weird enough that Android has this app under System apps. But the OS will not allow notifications from the Mobile App ...
- Sep 01, 2026
How is this MR6150 deployed? Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
And, if it is mobile, I would think it should be within reach.
I_Must_Know
Sep 01, 2026Tutor
I tried the trouble ticket route. Got a standard reply from the Help Support. But when I gave them the same information I posted here....."crickets" .
I should have just stayed with the M1 hotspot. Even with AT&T raising my grandfather old plan rates.
Sep 01, 2026Guru - Experienced User
What are you needing notifications for?
