I_Must_Know
Aug 28, 2026Tutor
Netgear Mobile App blocked notifications
Hello everyone. I've been unable to find a solution to this issue. It's weird enough that Android has this app under System apps. But the OS will not allow notifications from the Mobile App ...
- Sep 01, 2026
How is this MR6150 deployed? Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
And, if it is mobile, I would think it should be within reach.
I_Must_Know
Sep 01, 2026Tutor
I want battery status(this m6 runs way hotter than the m1), temperature status, firmware status,
Sep 01, 2026Guru - Experienced User
I usually keep mine plugged in or just do a quick check on the screen. Only takes a second.
