Deek56's avatar
Deek56
Netgear MR1100-100
My Nighthawk has suddenly stopped charging, a bit strange as it seems to have happened just when my support had ended, has anyone had a similar issue and a fix?
    • Deek56's avatar
      Deek56
      Hi All
      It turns out it was the Netgear charger plug that must have developed a fault, when I tried it with a different charger of the same specification (my phone charging plug) the MR1100-100 charged up fully.
      Problem solved.
