JasCola
Jun 24, 2019Aspirant
Netgear MR1100 constant reboot
Like many others here I have run into the issue where my device reboots. I have seen where others say it reboots every hour or so.. Mine is rebooting every single time a device even connects to the h...
AliasRat
Jun 30, 2019Tutor
I've run into the same issue.
It started randomly in my case on an existing unit that I've had for nearly a year.
Have tried all the same steps as per OP, but also included:
- changing WiFi transmit power/range between Low/Medium/High
- with/without WiFi Offloading
- disabling/enabling Cellular data
In all cases the unit still randomly reboots.
It did not happen until after I updated to the latest firmware (on the EUS version - NTG9X50C_12.06.03.00), but did not start happening immediately after the firmware update either so I can't say for sure if it's related).
- tazarian44Jul 06, 2019TutorAny new info? Will there be another update for the att model? I was hoping att would allow manual fw updates , but they don’t!
