JasCola
Jun 24, 2019Aspirant
Netgear MR1100 constant reboot
Like many others here I have run into the issue where my device reboots. I have seen where others say it reboots every hour or so.. Mine is rebooting every single time a device even connects to the h...
kreid
Jul 07, 2019Aspirant
Netgear, what is the status of this problem?
TL_NTGR
Jul 08, 2019Apprentice
Kreid,
Which model of MR1100 do you have? Can you provide the following details?
This tread started out as the AT&T Version of the MR1100 but has changed t the Euro version. Please help by including the information requested.
1) Under the battery is the product label. Do you seek MR1100-1A1NAS or MR1100-2A1NAS under the SIM icon? Or something differnt
2) Can you confirm the firmware version?
3) On the battery, can you share the P/N listed?
Thanks,
Tyler
- tazarian44Jul 08, 2019Tutor1. MR1100-2A1NAS
2. NTG9X50C_12.05.05.00
3. 308-10034-01- GabilloAug 31, 2019AspirantMine does exactly the same. Each time a client tries to login it reboots. Returning it in a couple of days if I can’t find a solution for this
