JasCola
Jun 24, 2019Aspirant
Netgear MR1100 constant reboot
Like many others here I have run into the issue where my device reboots. I have seen where others say it reboots every hour or so.. Mine is rebooting every single time a device even connects to the h...
talk2theis
Sep 18, 2019Aspirant
Have you found a solution for this issue. Mine is doing the same thing, rebooting after a device connects. I sure wish I would have seen this problem before purchasing. Thanks for any help!
Gabillo
didn't find a solution. Had to return via Amazon :-(
- kreidSep 19, 2019AspirantI believe some of the early models are hardware defective...I call support and asked for a replacement which the agreed to...new device does not have this problem.
- GabilloSep 19, 2019Aspirant
nice that it worked for you! But I've seen several people on the reviews having it to change for 2,3 or more times.
- tazarian44Sep 19, 2019TutorThey won’t replace mine ! Is yours branded ATT? How did you get them to replace it?
mine was not branded. I bought it through Amazon, and on the 3rd day I was returning it.
I bought this one:
It's incredible how 2 weeks ago I bought it for @$247 and now is going for $341
