JasCola
Jun 24, 2019Aspirant
Netgear MR1100 constant reboot
Like many others here I have run into the issue where my device reboots. I have seen where others say it reboots every hour or so.. Mine is rebooting every single time a device even connects to the h...
Gabillo
Sep 18, 2019Aspirant
didn't find a solution. Had to return via Amazon :-(
kreid
Sep 19, 2019Aspirant
I believe some of the early models are hardware defective...I call support and asked for a replacement which the agreed to...new device does not have this problem.
- GabilloSep 19, 2019Aspirant
nice that it worked for you! But I've seen several people on the reviews having it to change for 2,3 or more times.
- tazarian44Sep 19, 2019TutorThey won’t replace mine ! Is yours branded ATT? How did you get them to replace it?
mine was not branded. I bought it through Amazon, and on the 3rd day I was returning it.
I bought this one:
It's incredible how 2 weeks ago I bought it for @$247 and now is going for $341
- petr_kazdaNov 21, 2019Tutor
Netgear,
there is clearly an issue with your device. Multiple users are reporting problems, at my company this issue affects at least 3 devices, it started to happen after FW update.
Can you clearly communicate what is the status of the problem, how it is going to be solved and when? Or should we just take our devices and return all of them?
