JasCola
Jun 24, 2019Aspirant
Netgear MR1100 constant reboot
Like many others here I have run into the issue where my device reboots. I have seen where others say it reboots every hour or so.. Mine is rebooting every single time a device even connects to the h...
NewZJ
Nov 21, 2019Aspirant
I can't get more than 8 hours without it rebooting on me, sometimes it'll reboot multiple times an hour. I can't find a setting combination to keep it stable.
- tazarian44Nov 21, 2019TutorThe problem is firmware , att will not update firmware because it only affects minimal units! I’ve tried with att and netgear ! Neither will help or replace unit! Also when buying one outright from bestbuy , att will not unlock unit or warranty it when defective unless you have an account with them. So buying these you might as well say there is no warranty! I’m fed up with netgear blaming att and vise versa! Their Telstra ones have no issues because they are updatable via logging into the unit!
- TL_NTGRNov 21, 2019Apprentice
