SHADOW_KSA
Sep 27, 2019Guide
Netgear MR1100 dead not working
hello
my router Netgear MR1100-100EUS it's keep rebooting and not working if i put battery it's not rebooting it's like dead
6 time rebooting then stop working
in the video it's without battery
please help
Have you tried a different charger? it wouldn't be the first time a bad charge wasn't providing enough power to run a device. It usually takes the most power during bootup.
You also might need to reset it if its been crashing for so many bootups. Page 71-72 of the manual has options for resetting using the button or through settings.
plemans wrote:Have you tried a different charger? it wouldn't be the first time a bad charge wasn't providing enough power to run a device. It usually takes the most power during bootup.
https://www.netgear.com/support/product/mr1100
i tried 3 a different charger and not work
- I replace battery from another device and my device not working still same problem
another device with my battery work fine !!
- TeeJay74Virtuoso
Hi,
Have you tried rebooting without SIM card ?
- Yes I tried
- TeeJay74VirtuosoHi,
Your device needs service evaluation, current situation looks pretty bad.
- rajamidAspirant
hi had the same problem the router just reboots after the netgear logo diappears , then i opened the device and reballed the emmc and qualcom chip now it worked fine , its bcoz over time the soldering pads get weak it needs reballing of the ic .
