khaled10's avatar
Apr 24, 2021
NETGEAR MR2100
The device stops on the Net Gear logo and turns off
Removing the battery did not work
Attempt by cable directly without battery did not work
And also with the battery it did not work
Repeat this several unsuccessful attempt.
leave the device for a day, a week, and a month.
NETGEAR MR2100
Model: MR 2100
Firmware: NTGX24_10.17.08.00
Modem Version: SDX24_10.25.00.06
GUI Version: MR2100-100EUS_04.02.171.00
PRI Version: 05.04
Firmware Build Date 2020/08/21
  • khaled10's avatar
    khaled10
    Apr 27, 2021
    Yes
    There is no response.
