cbernhardt
Nov 16, 2023Aspirant
NETGEAR MR6110 MIFI Hotspot ethernet connection
I recently purchased an AT&T NETGEAR MR6110 MIFI Hotspot, SN: 76522CWVA1A8C for my business. The wireless connections work fine with all my computers, except my old Windows XP computer that does not ...
- Nov 18, 2023
I have everything working properly.
Thanks for your help
Charles
routersupport0
Nov 18, 2023Aspirant
Hi, cbernhardt you can try these steps.
- Make sure the subnet mask on your Windows XP computer is set to 255.255.255.0, as this is a commonly used subnet mask for local networks.
- Set the default gateway on your Windows XP computer to the IP address of the AT&T NETGEAR hotspot, which is 192.168.1.1.
- To set the DNS server addresses in the TCP/IP properties of your Ethernet connection on the XP computer, you may utilize AT&T's DNS servers. For instance, you can assign Primary: 68.94.156.1 and Secondary: 68.94.157.1.
- Verify if there are any proxy settings configured in your Firefox browser. If a proxy is being used, make sure it is configured properly or consider temporarily disabling it to determine if it has any impact.
- Check your firewall settings to make sure it's not blocking the internet connection. You may need to specifically allow traffic from the XP computer.
- Open the command prompt on your Windows XP computer and attempt to ping the AT&T NETGEAR hotspot's IP address (ping 192.168.1.1). This can assist in confirming the connectivity between the computer and the hotspot.
- Make sure the network adapter drivers on your Windows XP computer are updated. Old drivers can lead to connectivity problems.
- Ensure the Ethernet cable is in good condition and consider using a different one if available.
Hope that after trying these steps your problem will be resolved. One more thing I want to say Windows XP is no longer supported by Microsoft, it's worth considering upgrading to a more modern operating system for security and compatibility reasons
cbernhardt
routersupport0:
Thanks so much for your reply.
When I open the Network Connections on my XP computer I have two icons, one for the Local area Network (Ethernet) and one for the Wireless connection which shows "Not connected". I am assuming that the address changes that you suggested are for the Ethernet connection, correct?
In the settings for the wireless network none of the TCPIP addresses are set. "Obtain an IP address automatically" is checked and "Obtain DNS server address automatically" is checked.Do I need to set these addresses?
When I ping 192.168.1.1 four requests are sent and I receive 4 replys.
When I run the wireless adapter software the diagnostic test shows:
"Test failure: Your client adapter is not associated to an access point.
Solution: Configure the radio card and set SSID and other properties"
Ayn suggestions on what this means?
Thanks,
Charles
