NeilCroft91's avatar
Apr 21, 2020
Netgear night hawk m1
I have accidentally switched my device from 2.4ghz to 5ghz on my app, however my mobile phone cannot find the hot-spot now and i cannot connect back to the app to change it back without being connected to the hot-spot itself any help please 😭
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      The easiest way is to do a factor reset by pressing the reset button near the micro-SD slot.
      Or you can follow the steps below:
      1. Connect the device to your computer using USB cable
      2. Open Browser and visit 192.168.1.1
      3. Log in as admin with the password printed on the product label.
      4. Change the settings as you wish.
      • NeilCroft91's avatar
        NeilCroft91
        Tutor
        Can you please be a little more detailed after i login on that Web page please thank you :)
