DenLeigh
Jan 12, 2020Aspirant
Netgear nighthawk battery
Having problems with device too hot to charge battery- any suggestions?
Is it your environment or is the device hot from usage?
A laptop cooler could potentially help.
Or potentially the battery is going bad. How old is it?
- DenLeighAspirantOnly purchased device 3 days ago. Have tried charging in cooler times of the day and this helps a bit but usually due to the time it takes to fully charge the device is then too hot as it can take a few hours to charge.
I may have to get it replaced under warranty?- plemansGuru - Experienced User
Devices are going to get warm when they charge. Not sure how hot the devices is getting. Is it working? If its getting to hot, many will shut down.
