Babala1
Dec 08, 2022Follower
Netgear Nighthawk hotspot & Google Nest
I have a Netgear Mobile 5G hotspot that is the only thing I can use for WiFi. I bought a Google Nest WiFi Router to help extend the signal in my house. I was told all I had to do was connect the hotsp...
michaelkenward
Dec 09, 2022Guru - Experienced User
Which one? Netgear makes several, with different features.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
