YousefJ
Apr 12, 2019Aspirant
Netgear Nighthawk M1 Charging Issues
Hello, so I’ve been using the NETGEAR Nighthawk M1 MR1100 Mobile Router for a while now. And I noticed a little issue with the charging, whenever I leave it charging overnight (while it’s at 13% of ch...
Apr 12, 2019Guru - Experienced User
are you using the officially supplied charger? I couldn't find the specific power requirements but I'd check the power supply to make sure its giving the MR1100 enough amperage to fully charge it.
