YousefJ
Apr 12, 2019Aspirant
Netgear Nighthawk M1 Charging Issues
Hello, so I’ve been using the NETGEAR Nighthawk M1 MR1100 Mobile Router for a while now. And I noticed a little issue with the charging, whenever I leave it charging overnight (while it’s at 13% of ch...
YousefJ
Hello, Plemans. Yes, I think I am using the official charging adapter. The Type is: B07LF. Input is: 100-240V ~ 50/60 HZ. Output is: 5.0 V — 2.0 A. Would that be enough power for it to charge properly? By the way, keep in mind that this happened pretty recently, not when I first bought the router. The first time I bought the router did not have this charging issue.
Apr 12, 2019Guru - Experienced User
My bet would either be the charger going bad or battery going bad.
1. how long have you had it?Lithium has an expected shelf/usage life like a phone.
2. Do you have any other chargers you could try that at least hit that charging specs?
3. Have you changed cables recently? a bad cable could reduce power supplied. Or do you have a backup cable you could try to charge with?
- plemansApr 12, 2019Guru - Experienced User
have you restarted the device? Maybe its got a process running thats pulling a significan amount of power?
- YousefJApr 12, 2019AspirantI have restarted the device several times by the problem keeps occurring.
- YousefJApr 12, 2019AspirantSee below:
1- If you’re talking about how long I’ve had the device for (including the battery itself). I’ve had it for about 6-7 months.
2- I have other chargers that I could use but I am not entirely sure if it’s safe to use since I am not sure about the MR1100 power requirements, I will have to do research on that.
3- I haven’t changed cables at all, the official cable is plugged into the official adapter ever since I bought the router (MR1100).- plemansApr 12, 2019Guru - Experienced UserYou should be safe with a 2.4a 5v charger. The device pulls what power it requires. I'd try a different cable, then different charger.
It should be under warranty if it's only 7 months old. You could file a support ticket to get that process started before warranty runs out
