YousefJ
Apr 12, 2019Aspirant
Netgear Nighthawk M1 Charging Issues
Hello, so I’ve been using the NETGEAR Nighthawk M1 MR1100 Mobile Router for a while now. And I noticed a little issue with the charging, whenever I leave it charging overnight (while it’s at 13% of ch...
Apr 12, 2019Guru - Experienced User
My bet would either be the charger going bad or battery going bad.
1. how long have you had it?Lithium has an expected shelf/usage life like a phone.
2. Do you have any other chargers you could try that at least hit that charging specs?
3. Have you changed cables recently? a bad cable could reduce power supplied. Or do you have a backup cable you could try to charge with?
