YousefJ
Apr 12, 2019Aspirant
Netgear Nighthawk M1 Charging Issues
Hello, so I’ve been using the NETGEAR Nighthawk M1 MR1100 Mobile Router for a while now. And I noticed a little issue with the charging, whenever I leave it charging overnight (while it’s at 13% of ch...
Apr 12, 2019Guru - Experienced User
5v-2.4amp. The 5volt is the key.
Oxygene
Apr 13, 2019Apprentice
All Netgear routers have problems with battery charging. It looks like it is because router gets hot and they don't want to risk a fire. Just turn it off completely at night and charge it. I have some problems too while using a router and charging it at the same time... 810 model had the same issue.
- GmsuttonMay 30, 2025Aspirant
I need this for security cames and it’s only been a problem with most recent models.
