v5_rnas
Mar 01, 2017Aspirant
Netgear Nighthawk M1 drops LTe connection every day and requires multiple reboots
Hi there,
Purchased a Nighthawk M1 (MR1100) from Telstra recently. Seems to work well in terms of speed. But a few problems including severe lack of configuration for DHCP (the only item you ca...
ArodiD
Mar 02, 2017NETGEAR Expert
HI v5_rnas,
I have sent you a PM. Please check when you have some time.
papajohn3002
Apr 20, 2017Aspirant
Like others before me, I'm fed up with having to reboot my Nighthawk MR1 every time I stop briefly on my computer (MacBook Air) or when I close down my computer. I used a Sierra mobile router before which never required rebooting. The Telstra technician suggested changing the time-out feature under "Advanced" to "Never" but this makes no difference.
Can you please help?
papajohn3002
