mengnighthawk
May 19, 2021Aspirant
netgear nighthawk m1 keeps slowing down
I have a mr1100 that is connected to a router, followed from a YouTube video. anyways, my internet connection is att unlimited. my issue is that my internet speed keeps slowing down from 100mbps to le...
JohnPeng
May 20, 2021NETGEAR Expert
Please do a factory reset and try again.
If the issue still happens, please check with AT&T whether the network throttles your data.
Thanks
John
- bkellingMay 24, 2021Aspirant
JohnPeng could you please help me; i am having the same problem as him above and my router is extremely slow....also when i try to plug in the usb c into my xbox to have a direct tether for faster wifi it does not tether...i have selected the setting charge+tether but still does not work...anything helps thanks......I am unsure what you meant by your response to him above also
- JohnPengMay 24, 2021NETGEAR Expert
The device can be tethered to Windows or Mac due to default drivers loaded on the operating system. I don't think your XBox has the supporting driver for the device. That is why USB tethering will not work on your Xbox.
