GB1
Jan 06, 2019Follower
Netgear Nighthawk M1 MR1100 Battery swelling up.
Does any one know what netgear is doing about the Battery problem with the Nighthawk M1 wifi router. I can see where other people have had this problem on some other online discussions, but can not s...
Retired_Member
Mar 19, 2019I have had the same problem -twice with different routers (same model - netgear nighthawk m1) the battery swells up and pops out - very dangerous - telstra says to return it to the shop
- Blanca_OMar 24, 2019NETGEAR Employee Retired
Hi Retired_Member
How long have you been using the MR1100? Did Telstra replace the battery or whole unit?
Blanca
Community Team
- Retired_MemberMar 25, 2019Not too long - about 8 months before battery starts to swell - the guy at Telstra said you can use it without the battery, so that’s what I’ve been doing - they would have replaced the unit, if I gave them the router and battery, but I decided to just keep it plugged in.
