GB1
Jan 06, 2019Follower
Netgear Nighthawk M1 MR1100 Battery swelling up.
Does any one know what netgear is doing about the Battery problem with the Nighthawk M1 wifi router. I can see where other people have had this problem on some other online discussions, but can not s...
northern_chique
Jul 23, 2019Tutor
Same as the others with battery swelling. CW10718BN006302 Model Number W-10 3.8v 19.76Wh
P/N 308-10019-01
Purchased from Telstra. Unit started swelling 12 months into use. Battery removed. Unit powered by USB only. Telstra franchise stated "not their problem" even though the unit was still under warranty when first reported.
Evident that there are major issues with the batteries on these units. Suspecting there should be an active recall as there is a significant spark risk with the way the unit is distorting the connection if the case back is forced into place.
