ronaldvr2132's avatar
ronaldvr2132
Apprentice
Jul 06, 2018
Netgear nighthawk m1 mr1100 max size micro sd
What is the maximum size that the Micro SD Card installed in a MR1100 can be? The manual says 128 GB, but I have read on more places that 256 GB works as well. Is that correct and will every brand work? And is it possible to map the Micro SD as a network drive on a Windows 10 PC that is attached to the Wifi of the MR1100?
