GOROW
Jan 29, 2025Aspirant
netgear nighthawk m1 MR1100
Hello
a few days ago the message appeared:
Keine Verbindung mit diesem Netzwerk möglich (no connection possible to this network)
when I tried to connect any device to the MR1100. Any device means: a samsung mobile S23 with Android, a Microsoft surface with windwos 11, an apple IPAD pro with IOS 18.
What can I do to find out how to reanimate the MR1100 without access from a computer via WiFi to it.
Thanks for Help
Gorow
- rcpaxLuminary
I don't have an M1, but have you tried connecting the M1 to a PC via the USB port? If the settings were at default, this should allow for a USB wired tether connection with the PC, and you then are able to access the admin page webGUI via this method to troubleshoot. Also, if the settings were default, you should be able to just factory reset that as a last resort and start fresh if all else fail. Get a PDF manual from NG's website for additional help with these if you require it.
- GOROWAspirant
Hello
thanks for your answer concerning netgear nighthawk m1 MR1100.
The USB-connection to android, windows 11 and IPAD did not work.
I did a reset using the reset button on the router.
Now a WLAN-connection on the IPAD works; WLAN still fails with the wellknown errormessage. I will ask for support at netgear.de by eMail because I'm not a network specialist.
regards
