DLugar
Sep 18, 2020Follower
Netgear Nighthawk M1
I received a Netgear Nighthawk M1 mobile router today. I ordered it through Nomad internet. It comes with an activated ATT SIM card. I’m using this for my home internet and I have between 3 and 5 bars...
XxJamesAxX
Sep 19, 2020Aspirant
Did you figure anything out? I to just recently got a Sim from nomad and my speeds are about the same. I’m using it in my own device but my AT&T service iPhone gets 30-40mb and my router is getting .01mb. However mine did work fine for about 24hrs and then slowed. I’m wondering if we could both be experiencing the same issue and it’s with nomad? Thanks and good luck!
dah55
Sep 21, 2020Aspirant
I have a similar experience with Nomad. Their SIM card worked well for several days. Then speeds dropped from 30-40 mbs downloads to 0 mbps. Nomad said the card was programmed incorrectly and sent a replacement that arrived today. The replacement is still getting 0 mbs.
I sent an email and got a quick response with a link to setup instructions and saying to reply if it didn't solve the problem. After confirming that the M1 was set up correctly and connected to AT&T I wrote back to Nomad with screen shots. I have not received any further help.
I have to teach classes in the morning and only have a phone with limitied data to use.
