francsitdayalo's avatar
Oct 10, 2021
Netgear Nighthawk M2 - MR2100 - Wifi has red circle X and battery not charging
Hi, I recently got the Netgear Nighthawk M2 and I havent used it in a month, when i tried opening it it doesnt emit a wifi signal and the wifi icon has a red x on it. i tried turning ssid on and off and wifi still wont work
Second Problem:
I tried charging it for a trip and the  unit would just heat up and not charge,
i hope somebody could help me with this problem for i dont want to waste any money buying an expensive product like this
Blanca_O  Dustin_V
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Can you do a factory reset to see whether the issue goes away? Did you buy it brand new?
    Thanks
    • kazuar's avatar
      kazuar
      I have exactly the same problem. I got a brand new device and the wifi is not working from the beginning. Cable connection works fine. Any idea? Seems like this device is faulty.
