ugenswani
Aug 04, 2022Follower
Netgear nighthawk m6 pro Ethernet not working
So wifi works perfectly, but Ethernet is best for online gaming. Id like to not disconnect every 5 minutes. But of course gaming is never that easy for me, Ethernet offloading is unsuccessful every...
michaelkenward
Aug 04, 2022Guru - Experienced User
You don't say what the model number is of the Netgear device you own – "nighthawk m6" could be one of several things. Most of them are mobile modem/hotspots.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
