ugenswani
Aug 04, 2022Follower
Netgear nighthawk m6 pro Ethernet not working
So wifi works perfectly, but Ethernet is best for online gaming. Id like to not disconnect every 5 minutes. But of course gaming is never that easy for me, Ethernet offloading is unsuccessful every...
ArodiD
Oct 10, 2022NETGEAR Expert
Hi ugenswani ,
Are you plugging the xbox directly into the M6? If so, Ethernet offloading should be disabled. Ethernet offloading allows you to plug the M6 into your home router and use that connection as the primary internet. If Ethernet offloading is enabled(Ethernet port switches from LAN to WAN), the M6 may think your Xbox is a home router.
ArodiD
