hummous
Nov 25, 2022Guide
Netgear Nighthawk M6 Pro (MR6500) 5G hotspot randomly freezes a few times a day.
Bought the hotspot new from Best Buy. When it freezes, the wifi stays connected to devices, but there is no internet on the devices. The touchscreen and buttons on the hotspot do not do anything and ...
JohnPeng
Nov 27, 2022NETGEAR Expert
Could you please confirm this is AT&T MR6500 and you are using AT&T SIM card?
Thanks
- hummousNov 27, 2022Guide
Yes, confirmed.
- KuntryKenNov 28, 2022Initiate
I am having the exact same problem with the same Netgear Nighthawk M6 Pro (MR6500).
It is continuously freezing and the whole reboot/reconnect to towers and devices is more than 5 minutes.I replaced a Netgear Nighthawk 4g device with this one and never had a single problem out of the older and much cheaper than this one.
The battery clip does not work either and the battery continually falls out if you try to move it
- JohnPengDec 06, 2022NETGEAR Expert
AT&T just approved the maintenance release to address the data disconnection and Firstnet related issues. The upgrade is posted on the AT&T server. Please do manual upgrade check if you would like to get the update sooner.
Thanks
John
