Washy53's avatar
Washy53
Follower
Jun 10, 2021
Netgear nighthawk mk1 MR1100-100
How do I turn on the data on this device
SIM card is working I'm connected to the device but data is turned off!
TIA
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Washy53,
    Welcome to NETGEAR Community!
    Please check the display status on the device LCD if it says connected or not.
    Make sire that network coverage is available in your area
    Make sure that the SIM card is active and enabled with data services.
    Kindly turn off and on the MR1100 and restart the computer or WiFi devices then check if it can go online.
    Blanca
    Community Team
